DIY Service
Any VW technical problems - Post them here and someone will get back to you! :-)
DIY Service
Postby FarCanal » Sat Oct 19, 2013 8:12 am
Hi,
My '95 T4 1.9D needs a service, I've orderded the following
4 x Glow Plugs
Brake Pads
Oil Filter
Air Filter
Fuel Filter
Cabin Filter
What else would you recommend doing... Not done a home service before?
Also - Any horror's I should be wary of with any of the above?
Thanks.
FC..
"If I surf I'll put my body in danger... But if I don't surf, I'll put my soul in danger.."
FarCanal
Newbie
Postby Muppet » Sat Oct 19, 2013 7:24 pm
I'd suggest
1. A brake fluid flush as your putting pads on. They dont get done often, have done mine and pedal feels much better.
Get a caliper rewind tool as makes life so much simpler and helps to keep calipers free running.
2. Check/replace the Injector leak off pipes, small black cloth covered ones. couple of quid for a length.
3. Have a litre of diesel to hand to refill the fuel filter other wise it'l be a sod to start.
4. Something not on the list don't forget to get some oil :lol: :lol:
5. When did it last have a Coolant flush? what colour if is the fluid G12 is pink/purple or equivalent from GSF
MIke
Postby SiC » Sun Oct 20, 2013 3:54 pm
Spray all latches and catches and earths/terminals with white grease, put anti sieze and copper slip etc on everything you remove or fit...
Do your wash bottle with a good winter screen wash... Also consider wiper blades...
Check all your lights/bulbs
SiC
40 Dubs and Counting!!!!
Postby FarCanal » Mon Oct 21, 2013 3:28 pm
Hi,
Thought I'd do an update.
did most of what I wanted, Front Pads, All filters and oil changes.
I thought twice about the glow plug change as, as far as I know they're working, thought I'd give the cold start lever a go first!
Thanks for the advice, all was welcome and needed - fitted a new Oil drain washer..!
Only downside - I realised my Powersteering fluid was low - only topped it up couple of weeks ago, looked underneath while wheels were off and saw that the Gator? on the powersteering rack (long pole on each side of van attached to hub - Assuming its the rack) had split - so thats going to need replacing for MOT and looks a bitch of a job to do.
FC.
FarCanal
Newbie
Postby regcheeseman » Mon Oct 21, 2013 8:07 pm
You made the right choice there. They are a pig to do, and really only worth doing when you have a problem. You should never need cold start advance in our climate, if you find you are using it - there may be issues elsewhere.
Unfortunately the rack boot will not cure your fluid loss.
regcheeseman
Postby Muppet » Mon Oct 21, 2013 8:13 pm
Sounds like the power steering
What colours the fluid? Nice dark RED??
Done a fluid flush on mine its a lot less noisy at
full lock and now only does it slightly if you hold it on lock.
Not had to do a power steering rack myself
best of luck
Postby regcheeseman » Mon Dec 23, 2013 11:35 pm
Replacing the power steering boot isn't that tricky, replacing the rack however is a chuffing nightmare.
regcheeseman
Return to Technical Forum
Users browsing this forum: No registered users and 0 guests
