Heat Exchanger Cables
Any VW technical problems - Post them here and someone will get back to you! :-)
Postby NickV » Fri Mar 21, 2014 12:39 pm
Hi all,
doing a few fettling jobs on the 182...[1974 Trekker RHD]
My heater has been half on or full on for years, finally got round to starting job.....!
Anyway, it seems the flaps inside were stuck half open and not returning- went mad last night with lubrication and lots of waggling, now they return nicely....
The cables themselves were connected with a kind of bodged up electrical connector type thing to the arms, was a bit knackered/crap looking!
MY question is, what should be on the end of the heater cables [engine end], if anything, or is it meant to be bare wire [for example is there anything crimped on etc.?] that feeds in to the connectors on the arms.
Just want to check to see if they are saveable, think they are fairly cheap so might be worth doing anyway...
Cheers
Nick
NickV
waffle gagger
Re: Heat Exchanger Cables
Postby funkyfreakapotomus » Sat Mar 22, 2014 10:23 am
There is a bit in this thread called "the heat exchange cable" which I am sure would be the same???
Its illustrated (but for a T2) and shows what the ends of the cables look like!
http://myweb.tiscali.co.uk/freemefromth ... eating.htm
Hope it helps!
1964 Canterbury Pitt
1968 Bug (under construction)
Keep it stock
High with pride
funkyfreakapotomus
Postby NickV » Sat Mar 22, 2014 5:04 pm
Nice one, that is a perfect link, will read carefully and answers the question!! They do, and my cables were toast! :D
Have stripped everything out this afternoon, and awaiting a bundle kit of all the bits and bobs.
Cable is only £3.50- crazy that someone did a bodge to save that....
Next am going to think of a way to coat my original VW heat exchangers to make them last that bit longer, as they kick out heat nicely!
Cheers mate
Nick
NickV
waffle gagger
Postby GBHgpJON » Sat Mar 22, 2014 6:04 pm
Leaky rocker covers will help...........altho, I think the main problem is they rust from the inside out, as in most exhausts.
Postby funkyfreakapotomus » Sat Mar 22, 2014 6:34 pm
Glad it helped and good luck!! :-D
Keep it stock
High with pride
funkyfreakapotomus
Return to Technical Forum
