Why?.........
Why?.........
Postby GBHgpJON » Wed May 01, 2013 9:16 pm
.......is petrol getting into GBH's oil, when I dont have an mechanical pump.....I guess thru the carb........but why??.......are we looking at a dripping throttle pump? Had a look and cant see anything dripping......any other suggestions?
Sensible ones only tho(Steve)
Postby Globbits » Wed May 01, 2013 9:49 pm
Petrol into the oil? Could be:
Knackered rings
Knackered valve seals
A special petrol-flavour oil you bought without realising
I can't see how it would be carb-related, as there's no oil near the carb to get contaminated (but would welcome being proved wrong, as two of my three suggestions are unpleasant and the other is stupid)
Postby jason gallagher » Wed May 01, 2013 10:30 pm
i had an old honda cb200 like that , the sump just kept on getting fuller and the oil thinner
all i realy wanted was a hot rod
jason gallagher
Postby TawCottage » Thu May 02, 2013 8:19 am
jason gallagher wrote:i had an old honda cb200 like that , the sump just kept on getting fuller and the oil thinner
You obviously never found out why?? :wink:
Life is not a rehearsal
TawCottage
Postby TawCottage » Thu May 02, 2013 8:30 am
Hi Jon
Have got my serious and sensible head on :wink:
Have a look here
http://www.vw-resource.com/gas_oil.html
Steve
TawCottage
fuel in oil
Postby Chilliman » Thu May 02, 2013 11:19 am
If you're running an electric pump the only way is the rings & valves but you must be smoking pretty badly?
With a buggy ..
it can get really cold being COOL!!
Chilliman
Chat Virgin
Postby GBHgpJON » Thu May 02, 2013 3:38 pm
No smoke.......new rings!
Looking at the dip stick, it's added an inch to the level....... :shock:
Altho Steve's link may shed some light.........Serious Steve, that is.....:wink:
Possibly a slightly tired float valve, combined with me lifting the tank up and resting it on the bulk head and leaving there for a while may explain it.......... :roll:
Oil change and new float valve, and see what happens......... :D
Postby jason gallagher » Thu May 02, 2013 9:11 pm
no steve i pxed it on mtx 200
jason gallagher
