t25
t25
Postby doorman » Tue Sep 25, 2012 6:32 pm
hi does any one have acomplete exhaust including manifolds for a 2.1 injection t25. or know if a 1.9 carb exhaust will fit
doorman
Newbie
Postby Globbits » Tue Oct 02, 2012 11:04 am
I would expect the fuel-injected version of the system would have some form of lambda sensor in the exhaust? If this is the case, then a 1.9 carbed version definitely won't work
In any case, I'm pretty sure the 2.1 exhaust is a bigger bore than the 1900 version. So if you were to fit it, you'd probably find your engine was a little strangled :cry:
Postby blackrat79 » Fri Jan 25, 2013 11:09 am
yes I do pm me :D
blackrat79
Newbie
