Non functioning speedo.
Postby Jimbo261 » Tue Aug 28, 2012 7:45 pm
Hi All,
The speedo on the Beetle's not working.
I've replaced the grease cap as the hole was round, the cable is rotating at the speedo end and if I put something in the drive hole and rotate it the speedo registers.
BUT, when it's all connected up no reading! :cry:
Any advice or solutions before I start searching for a new speedo? :?:
Thanks.
Burning fossil fuels since 1987.
Garage full, Son's Bug, Audi TT, Renault Scenic, Volvo V50 (pile of crap company car), Buell XB12X and Suzuki GSXR400R.
Jimbo261
Newbie
Postby SiC » Tue Aug 28, 2012 8:00 pm
Have you got circlip on end of cable at dust cap end? Are you pushing cable fully home in speedo before screwing the outer retaining cap on?
SiC
40 Dubs and Counting!!!!
Postby Jimbo261 » Tue Aug 28, 2012 8:03 pm
Yes to both.
Jimbo261
Newbie
Postby GBHgpJON » Tue Aug 28, 2012 8:15 pm
End of the cable worn/out of square? ......or the 'female' bit of the speedo worn or 'rounded?.........
Postby SiC » Tue Aug 28, 2012 8:16 pm
Which case either your cable or speedo head are dead! I'd try a cable first....
How did it stop working? Was it noisy or bouncy first? Has the mileometer stopped too?
SiC
Postby Jimbo261 » Tue Aug 28, 2012 8:20 pm
Cable end looks fine, I'm thinking it must be the head.
No idea how it stopped, it wasn't working when we bought it. the previous owner said she put a suitcase in the boot and that made the speedo stop, which sounds unlikely to me.
Odo not working either.
Jimbo261
Newbie
Postby Muppet » Tue Aug 28, 2012 8:29 pm
Hi ya
If you pop the Old cable core out and put it in the speedo does it
turn by hand.
If so you might need to shorten the Cable Outer to make the inner
protrude further into speedo. IF you know what I mean.
I'm in all week doin bits on the van if you wanna pop round.
No daily as waiting for it to return from the Menders.
Postby Globbits » Tue Aug 28, 2012 8:52 pm
Are you sure the cable is still in one piece? If it's snapped in the middle, then the wheel end will appear to turn but the inside end won't move
For the time it'll take, put a jack under the car, lift the wheel off the ground and give it a spin with the speedo end removed
Richard
Postby Jimbo261 » Wed Aug 29, 2012 6:14 am
Cable definatly in one piece as I've already removed it from the outer cable when I cut about 3mm off the end to get more inner in the speedo. Also already on a jack to replace the grease cover.
I'm going to shorten the outer a little more tonight and when that doesn't work ( lol) I'll go see Muppet!
Thanks all.
James
Jimbo261
Newbie
Postby Jimbo261 » Mon Sep 10, 2012 6:55 pm
:oops: :oops:
After all the struggle I made an startling discovery,
it's not possible to jack the car and spin the wheel by hand fast enough to make the speedo register!
:oops:
Huge thanks to Muppet for the offer of help, made the discovery when driving to his house, still, not a wasted journey as he fixed the wipers that broke on the way there!
Cheers again mate. :wink:
Jimbo261
Newbie
Postby SiC » Mon Sep 10, 2012 7:53 pm
lol......... :wink:
SiC
