Engine Rebuild
Postby Muppet » Mon Nov 26, 2012 10:46 pm
Second coat finished this evening.
give it a couple of days before I touch it again to fully set as little cold
in the garage.
EDIT:- Thought this was a bit too FAR :shock: :shock: :shock: :shock:
http://www.nsra.org.uk/newforum/showthread.php?t=44641
Postby Muppet » Fri Dec 21, 2012 9:55 pm
Ok
Might actually get a bit done now I got a few days off
paint dried nicely and seems to have stuck to the important bits
Plan to get the block rebuilt first,
need crank seals first
auxilary drive seal
looking for new Oil pump & Vac pump
wunda what santa will bring me
Postby mikey » Sat Dec 22, 2012 7:44 am
Looking good there Mike.
Steve Lang on the nsra does turn out some nice hot rods.
Yesterday's history, tomorrow's a mystery, live today.
mikey
Postby Muppet » Mon Dec 24, 2012 8:24 pm
bit of tinkering today as had the day off
Them Piston ring compressors are worth all they cost would of been at it for hours
New main bearing shells fitted, big ends are fine.
Had been round the whole block with the Tap set to ensure all the threads clean
Big ends & Main bearings all torqued to spec as well as thoroughly lubed during assembly
Now getting on with fettling me valves, bedding them in takes ages.
Postby mikey » Tue Dec 25, 2012 6:45 am
Good work.
mikey
Postby Muppet » Sat Jan 19, 2013 6:34 pm
Got me Crank Seals so that almost complete.
Postby JOE » Sat Jan 19, 2013 8:30 pm
Muppet wrote:Got me Crank Seals so that almost complete.
:D :D
JOE
Water Cooled W.A.N.C.er
Postby Muppet » Thu Feb 21, 2013 10:35 pm
Got me some new Cam Followers so this weekend its head rebuild time.
Valves lapped in already just need to give the head a good
clean and then rebuild will start.
will prob have few pics over the weekend
Postby Muppet » Sat Mar 02, 2013 5:29 pm
Ok been in the garage today
managed to get more of the engine put together than I thought I could with the seals that are missing
even though it was a tad chilly in the garage
Head on & bolted down, Them Bolts have to go Real Tight :shock: :shock:
But fortunately I didn't need my scaffold Pole.
At least I know where my timing marks are without a Flywheel & bell housing.
Just need to find all the bolts but some will be in the van already so changed back when re-fitting occurs.
Next to see Regcheesman about Pump rebuild/recon so it don't Pi55 diesel every where 5 mins after fitting.
Postby mikey » Sun Mar 03, 2013 7:19 am
Looking good there Mike, back on the road soon. :lol:
mikey
Postby Muppet » Sun Mar 17, 2013 10:30 pm
Thanks to Regcheeseman for a Dizzy pump rebuild
Dizzy now fitted a 2nd time after I realised its easier to fit the Glow plugs &
Injectors with it off. Just Torqued the CrankPulley bolt 90nm +90'
Hoping to fit timing belt Monday evening
Then have to re-arrange the garage to get the engine at the right end.
Getting there eventually
Postby Muppet » Mon Mar 18, 2013 9:17 pm
Ok looking little further tonight.
Pump attachet & Gates Timing belt kit fitted.
Timed up easy enough every thing stayed where I set it.
Manually cranked it over and no Clunks or Crunchy bits.
Need to prep the van soon for the impending Donation!
Postby Globbits » Mon Mar 18, 2013 9:34 pm
Well done bud!
You can do mine next :wink:
Postby Muppet » Mon Mar 18, 2013 10:03 pm
gotta see if it works yet
:lol:
Postby mikey » Tue Mar 19, 2013 4:39 pm
Keep the good work up Mike, your doing a great job. 8)
mikey
PreviousNext
Users browsing this forum: No registered users and 3 guests
